Ga door naar hoofdinhoud
1.6, 1.8, or 2 GHz G5 processor
20 Vragen Bekijk alle
My iMac desktop will not turn on.
I bought my IMac around 2009 and have never used it. I mostly stay on my iPhone and iPad. I know it sounds crazy that I never hooked it up. I sat down today hooked every thing up but it will not come on. I wonder since it sat so long not used hurt it.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
This system had issues with bad capacitors Capacitor plague. It likely needs a new power supply as well as PRAM battery.
Now the real question is if its worth fixing? This system can’t run anything newer as it was based on the RISC chip architecture of the IBM PowerPC chip. Todays systems use the CISC based Intel processors. As its so old it won’t work with your iPhone or iPad with the latest firmware on them.
It you need a new system I would look at a used 2011 or newer iMac or 2012 or newer MacBook Pro.
Was dit antwoord nuttig?
Voeg je antwoord toe
tsulzby zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 11
Altijd: 97
