Ga door naar hoofdinhoud
An Android smartphone produced by Samsung released in January 2017.
77 Vragen Bekijk alle
How could I replace the screen glass? (just the glass, not the screen)
Hi, my phone screen glass broke, I was wondering how could I replace the sole glass. Do I need to apply heat?
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
you can check on youtube but if you are not skilled or experienced in lcd refurbishing i would leave it to someone who is as the newer samsung lcds are very thin and you need some equipment such as a hot plate and special wire to seperate the glue and a laminating machine to apply the oca sheet and polariser and a bubble removing machine to remove air between the lcd and glass and a mould.
Was dit antwoord nuttig?
If you have to ask if you need to apply heat you shouldn't be doing it.
Voeg je antwoord toe
Narce zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 3
Altijd: 56
