Ga door naar hoofdinhoud
This is the first generation of the Ford Escape, a compact crossover SUV. Production started in 2000 for the 2001 model year.
104 Vragen Bekijk alle
2005 Ford Escape is stuck in park and no brake lights.
Brake switch is fine, no brake lights and stuck in park . I can over ride the safety lock to drive the vehicle but no brake lights. I have been told about a million reasons?I would think that the Shift interlock solenoid would be next? Any suggestions before i tear the console apart? Thanks.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
I had a similar problem on the same model vehicle.
I ended up switching out the gear shiftier assembly with a used one and it worked again.
Not sure how much help that was, but figure id share my success.
Good luck!
Was dit antwoord nuttig?
Voeg je antwoord toe
Ian Ochitwa zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 5
Altijd: 778
