Ga door naar hoofdinhoud
Model A1059 or A1099 / 20, 40, or 60 GB hard drive / touch sensitive click wheel
20 Vragen Bekijk alle
Enclosure for iPod classic hard drive
Power source for iPod Photo 4th Gen (60gbs) died. I tried replacing battery but no joy.
Is there an enclosure or adapter o can use to transfer songs off the drive and then format as either a portable hard drive or as additional storage on a Mac Pro?
James C.
Is dit een goede vraag?
Voeg een opmerking toe
3 Antwoorden
Gekozen oplossing
You can access this ZIF drive using a Universal Adapter:
Universal Drive Adapter
Turn your current hard drive into an external drive with this adapter. Afbeelding
Product
$24.99
Was dit antwoord nuttig?
Score 3
It may be the hard drive which has failed. If so your out of luck. You can still get some use out of it with this cheap fix
1 Opmerking:
Avais -
Thank you for your reply and attached solution. I was assured by the guy that diagnosed my iPod that the drive was fine, it is just the power module is defunct.
Regards,
James
door
This is exactly what you need: ZIF HDD caddy: https://amzn.to/42furqD
Voeg je antwoord toe
James Coogan zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 10
Altijd: 524
