Ga door naar hoofdinhoud
Handleidingen voor reparatie en demontage voor koelapparaten van levensmiddelen, waaronder koelkasten, diepvriezers en koel-vriescombinaties.
1699 Vragen Bekijk alle
Ice maker (Whirlpool wrs325fdam02) not working right.
The problem: ice is no longer being made. Water dispenses fine. Ice control arm is in the lower (on) position.
Attempted fixes: replaced water filter, replaced ice maker (entire unit) and replaced the water control valve.
Ice maker is cold enough. Water pressure is high enough. What am I missing? Water is not being called for in the ice maker? New control valve installed 2 days ago at water intake.
Is there anyone that can direct me to something I might have missed here?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
You’ve replaced the major issues. Now for minor ones to look at.
Cause 1
Door Switch
The door switch turns off the ice and water dispenser when the refrigerator door is open. If the door switch fails, the dispenser will not turn on. To determine if the door switch is defective, use a multimeter to test it for continuity. If the door switch does not have continuity when activated, replace it.
Cause 2
Icemaker Mold Thermostat
The icemaker mold thermostat monitors the temperature of the ice mold (ice tray). Once the mold reaches the proper temperature, the icemaker ejects the ice cubes and refills the ice mold with water. If the mold thermostat is defective, the ice maker will stop making ice. To determine if the thermostat is defective, use a multimeter to test it for continuity. If the mold thermostat does not have continuity, replace it. (Note: If the ice maker is not cold enough, the mold thermostat contacts will open. If the thermostat contacts are open, the ice maker will not make ice. The ice maker temperature must generally be lower than 20 degrees Fahrenheit for the thermostat contacts to close.)
Was dit antwoord nuttig?
Score 2
2 opmerkingen:
Ice maker thermostat is in the icemaker unit isn't it? I replaced the entire unit. Or is it separate and located elsewhere?
door
Door switch lights up the freezer section. Is there another door switch?
door
Voeg je antwoord toe
Brother Rain zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 33
Altijd: 3,063
