Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
De HP 15-laptop kan worden geïdentificeerd aan de hand van het modelnummer R263DX.
How do I boot from a CD?
I put a CD with Ubuntu on it in my laptop, then turn off and turn on my laptop. As it stars up, I hit the "f" buttons, and it does not bring up the bios menu I was expecting in order to boot from the CD. I tried holding the function (fn) button and hitting f1, f2, all the way to f12. I tried hitting escape, and delete. Nothing keeps it from just starting up in Windows 8 like usual. What do I do to boot from the CD?
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
2 Antwoorden
Filteren op:
With it having a UEFI Bios you will have to press the ESC key first to pause the boot, then you will get a list of boot options.
Was dit antwoord nuttig?
Hi, happy to help. please boot system WithOut CD in drive. Then please explain screen boot of your machine\Pc from boot.... if your trying "F" key make sure you hold the correct key until,,menu loads.
1 Opmerking:
Ok, when I boot without CD in drive, it starts as a black screen with the hp logo in the center. Below that, a collection of small white dots travel in a circle in a way that says "thinking...", then the screen turns bluish purple, and in the center of the screen, it says "Please wait", and the same white dots run in a little circle. A moment later, my login screen appears. I enter the password, and it goes to windows. Holding escape, delete, or fn f2 does not alter this.
door Deel
Voeg je antwoord toe
Andrew Lipiansky zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 15
Altijd: 652
