Ga door naar hoofdinhoud
model number A1763
Why are my beats x not turning on
My beats will flash white 3 times and appear red when on charger indicating they are charging but they won’t turn on please help I’ve tried resetting but it does not work and the guide on reddit was way to complicated
Is dit een goede vraag?
Score 2
1 Opmerking
Beats x on charger ….keeps blinking red to white ……will not turn on
door
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
I would try updating them. It might be a simple software issue. Otherwise it would be that the port is damaged.
Was dit antwoord nuttig?
Score 1
4 opmerkingen:
I’ll check to see if that works thanks for the help
door
I tried updating them and I know there charging because the light turns on and the firmware update didn’t work
door
Same issue. Apple support says they are defective and wants $80 to replace them since mine are 14 months old. Crappy product and poor support.
door
Mine are still under warranty I got em in December
door
You are a doughnut fool !$$&* you need to use a Samsung charger not an iPhone charger go to auction to get a username which has £200 minutes in the account mohamedrashid00
Voeg je antwoord toe
Silentgunner COD zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 18,351
