Ga door naar hoofdinhoud
Guides for the Wi-Fi version of the iPad Mini 2. Announced October 22nd and released November 12th, 2013. The iPad mini 2, also known as the iPad mini with Retina Display, has all the pixels of the iPad Air in a smaller 7.9" form factor.
I don’t know what to choose!
So basically everything is good on my iPad except for the screen. I cracked it. So what do I need to choose?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
This is the guide you need to follow. I highly recommend you go through the guide first to see if you are up to this. The iPad mini is one of the more difficult repairs.
Get the All New / Fix Kit / With Adhesive here to match the color you require.
Replace a screen digitizer compatible with the 1st or 2nd gen iPad mini models A1432, A1454, A1455, A1489, A1490. Part #820-3291-A, 821-3291. Home Button and Digitizer Cable included. Afbeelding
Product
iPad mini 1/2 Screen Digitizer
$34.99
Was dit antwoord nuttig?
Score 2
Voeg je antwoord toe
Caleb Elliott zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 45
