Ga door naar hoofdinhoud
Wi-Fi only version of Apple's 2nd generation iPad Air. Model A1566.
20 Vragen Bekijk alle
Bad charging and Error 4013
Hello :-)
I have an very weird issue on a customers iPad Air 2 Wifi Version.
First of all its not booting, not even the Apple Logo appears.
Second thing is that when I plug it in for charging on my MacBook, nothing happens as well, the screen remains black.
When I plug it in to the 12W iPad Charger, after some minutes on charging, it tries to boot, but the iTunes symbol appears and tells me to restore the device.
When I try so, Error 4013 appears.
Of course I've tried it in DFU Mode ;)
Some research on this lead to a defective NAND chip, but im curious if not maybe the battery could be the issue..
Before I send the device to a technician who's able to swap the NAND chip, I would like to know if somebody here had the same issue and probably a solution that does not require any kind of microsoldering.
Would be happy for any kind of tip.
Thanks and have a wonderful day people :-)
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
honestly i would try changing the battery before anything it sounds like it is not getting enough juice . i would also contact apple and see if they can run a diagnostics on it.
Replace a 7340 mAh battery compatible with iPad Air 2 A1566 and A1567 model tablets. Part #020-8558. 3.76 Volts (V). Battery model A1547. Afbeelding
Product
iPad Air 2 Battery
$54.99
Was dit antwoord nuttig?
Voeg je antwoord toe
jimmy industries zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 642
