Ga door naar hoofdinhoud
The Chevrolet Cruze is a compact car made by the Chevrolet division of General Motors. The Cruze was first released in 2008 with a front-engine, front-wheel-drive layout.
ODB2 give error P0136
There is two errors appear when i read ODB
  1. P0136 O2 Sensor circuit bank 1 sensor 2 (current fault)
  2. P0136pd O2 Sensor circuit bank 1 sensor 2 (undetermined fault)
Where i can find the o2 sensor 2 in the bank 1? and how can i fix this error?
My car info: Cheverolet cruze 2012, 1.6 petrol
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
As your car is a 4 cylinder it only has bank 1 . It does have sensor 1 and sensor 2. Sensor 2 will be the O2 sensor behind the catalytic converter in the exhaust system . replacing the sensor will probably fix the issue however its always a good idea to check the wiring around the sensor as they have been know to get burned by the exhaust pipes. when reinstalling the new sensor keep the wires clear of the pipes . This site will help with understanding the O2 system
https://www.aa1car.com/library/oxygen_se...
Hope this helps
Was dit antwoord nuttig?
Score 4
Voeg je antwoord toe
Abdul kader Zein Eddin zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 15
Altijd: 2,374
