Ga door naar hoofdinhoud
Uitgekomen op 4 november 2017. Model A1865, A1901. Verkrijgbaar als GSM of CDMA / 64 of 256 GB / Zilver of Space Gray. (Uitgesproken als "iPhone 10".)
Setup face id later
Hello my iphone x face id is not working its showing setup later
This issue i m facing from last 1 week
Last time i was used it in pool and after 5 hour it works fine when i check it in morning it was not working
Is it possible to replace it with new one?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Your iPhone X was in the pool? The X is water resistant, not water proof. Any issues you are seeing now are almost certainly related to water infiltration. What's more, FaceID is coded-locked to the phone so it is not repairable. Apple could do it but they won't touch a water damaged phone.
At this point, you either replace the phone (do a backup while you can) with Apple or have it decontaminated by a shop that specializes in this and hope that there aren't any long-term issues that crop up. If you want to try to cleanup the phone yourself, see my canswer to this question (Water damage repair cost or fix).
Was dit antwoord nuttig?
Score 3
2 opmerkingen:
So i hve to use it now without face id ? Apple store also rejected it
door
Unfortunately, yes. I would still be concerned about latent issues.
door
Voeg je antwoord toe
Khan zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 2
Altijd: 6,083
