Ga door naar hoofdinhoud
16.0 MP Digital Camera with a 30x long range zoom and 3.0-Inch LCD.
12 Vragen Bekijk alle
How to recover lost photos after processing in Adobe Illustrator?
I have to deal with the processing of photos all the time. I use Illustrator to edit and load. I never had reason to doubt this program until today's unusual problem. Instead of a large photo, the computer opens an error message that the file is corrupt and can not be opened. How can I return it? I do not have time to fix everything.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Then you can't open .ai file via any method apply more powerful solutions as ai file repair software
This one blog is very interesting, it is related your issue - http://smallbusiness.chron.com/recover-w...
It is the source of guide below: https://helpx.adobe.com/illustrator/kb/t...
Place the damaged Illustrator file in a new Illustrator file.
Important: This solution doesn't work if you didn't select Create Compatible PDF File in the Illustrator Native Format Options dialog box when you saved the original file. On the Macintosh platform, the damaged Illustrator file may appear dimmed in the Place dialog box, but you will still be able to select it and place it in the new Illustrator file.
1. In Illustrator, choose File > New.
2. Select the appropriate size and color mode, and then click OK.
3. Choose File > Place.
4. In the Place dialog box, choose All Formats from the Files of Type pop-up menu (Windows) or choose All Documents from the Show pop-up menu (Mac OS), choose the damaged file, and then click Place.
5. Name and save the file.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
XtoumoAvila zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 45
