Ga door naar hoofdinhoud
Sony Xperia Z4 (known as Sony Xperia Z3+ in Europe). Smartphone with 5.20-inch 1080x1920 display powered by 1.5GHz processor alongside 3GB RAM and 20.7-megapixel rear camera. It was released in 2014.
20 Vragen Bekijk alle
Not charging after replacing battery
Hi, i just received a new battery for my Xperia Z3+ Dual (LIS1579ERPC).
I replaced it and it's not charging anymore. Conector seems to work because it makes the sound when connected and PC recognizes it but battery icon does not change to charging status and under batter menu it says "not charging".
Tried with USB and original charger. Both with the same result.
New battery is on 20% charge. I didn't do what the note inside the package says to drain it to 10% and charge it to 100% uninterrupted because of the problem explained above.
I tried putting back the old battery and it's charging OK. I don't have another phone to try the new battery.
What can i do?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
It's a faulty battery. Try contacting the supplier / seller you got it from for a replacement.
Was dit antwoord nuttig?
Score 2
1 Opmerking:
Thanks, i bought it from iFixit and used a forwarder so sending it back for a replacement is not an option.
door
Voeg je antwoord toe
Andres Maidana zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 3
Altijd: 217
