Ga door naar hoofdinhoud
Repair information and guides for the iPhone 6S Plus that was released on September 25, 2015. Model A1687, A1634
1041 Vragen Bekijk alle
Killing batterys unexpected shutdown at around 50%
Hi I have a iPhone 6s plus that I have had to replace battery around 8 times as the battery works fine for around a month then dies at 50% like its flat pug it in I get 50% than continues till the battery is completely drained replace battery then like new for another month it's be like this since it was stolen from me and I got it back smashed now I'm about to replace the U2 Ic but I want to no if anyone knows of any other chips that can cause this so I can repair
Update (06/29/2018)
Hi again I'm really stuck with this one I have replaced Tigris Ic mosfet ic tristar ic I'm unsure if it's fixed the shutdown issue yet but in addition to that I have released its going through power like nothing one hour YouTube video used about 30% so I looked at big pmic and found caps c2016 c2013 c2017 c2020 c2014 c2015 c2019 and c2021 all to be shorted can anyone help with this issue as I'm sick all I can think of it replace the pmic and no sines of water damage or corrosion gave it a ultrasonic bath
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
In addition to replacing the U2 IC, I would recommend inspecting the board under a microscope to look for corrosion or deposits (as a result of water damage) that could be shorting out connections, this would lead to excess battery drain. If there is corrosion/deposits from water damage, the first thing I would recommend is a good cleaning.
Was dit antwoord nuttig?
Voeg je antwoord toe
dylanrichter44 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 2
Altijd: 116
