Ga door naar hoofdinhoud
Huawei’s first smartphone with the new Kirin 970 chip. Released November 2017.
17 Vragen Bekijk alle
My phone fell in water
My phone fell in water when im taking a shower. the speaker doesnt work properly. what should i do about it. it sounds cracky
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Clean every connection with a soft toothbrush. As well clean the logic board; use a 99% isopropyl alcohol for all cleaning. Now is the time to start drying out the phone. Set the screen in a desiccant or silica gel leave it in for several days moving it from time to time to get the max effect from the desiccant. Use a blow dryer on a low heat setting to dry the rest of the phone. Only use a hair dryer once you have cleaned the phone completely with the alcohol. Do not attempt to dry the phone if it’s still wet with water with the blow dryer as this only spreads the water. Replace the battery with a new one considers the old ones done. Clean again with isopropyl alcohol let dry and when you think everything is clean and dry reassemble the phone (make sure to clean the contacts on the screen after removing from the desiccant). Once you've reassembled the phone it’s time to power it on. Hold your breath and hope for the best
Huawei Mate 10 Pro Teardown
Replacement speakers can be found here
Hope this helps
Was dit antwoord nuttig?
Score 2
Voeg je antwoord toe
CharlieGraal Studio zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 11
Altijd: 3,572
