Ga door naar hoofdinhoud
2.6 GHz dual-core Intel Core i5 processor (Turbo Boost up to 3.2 GHz) with 3 MB shared L3 cache. Released February 13, 2013.
Upgrade original SSD to Samsung 970 Pro M.2 drive 256GB
Hello
I have a MacBook Pro 13" Retina Display Early 2013 with the original SSD drive it came with.
I would like to upgrade to the much faster Samsung 970 Pro M.2 drive 256 GB or something similar. But, I can't find out if its possible or how to do it.
Hope someone got an answer for me.
Is dit een goede vraag?
Score 3
Voeg een opmerking toe
5 Antwoorden
Gekozen oplossing
There’s more to it than sliding in a M.2 SSD into a Mac system.
Apple uses a proprietary blade interface so you can’t use a M.2 drive. I would recommend sticking with either one of the custom Apple drives listed here The Ultimate Guide to Apple’s Proprietary SSDs jump down to Generation 2 section. Or, go with either one of the third party drives made by OWC to Transcend
Last issue here is you can’t use the faster PCIe/NVMe drives as the systems interface is only SATA based.
Was dit antwoord nuttig?
Score 4
3 opmerkingen:
I went with a Transcend internal SSD and it was a very simple swap.
They also included a hard shell with a USB output so I can use the old SSD as a thumb drive (big thumb drive)! I love this set up.
Now that I ran out of storage again I had the same question; so I went with the
Samsung X5 Portable SSD - 500GB - Thunderbolt 3 External SSD (MU-PB500B/AM) Gray/Red
I had no idea I was a storage hogg
door
Not enough capacity. 960GB is too small for me.
door
@Jim Breef - The newer MacBook Pro's (2014 & 2015) offer a PCIe/NVMe unlike this series which is only mSATA. You'll need to get a newer system then you can use a 2 TB drive!
door
You can upgrade MacBook 2013/2014 with NVME drive (sort of) but you’ll meet few problems after that.
First of all you have to upgrade your MacBook EFI by installing High Sierra, then you can attach NVME drive with adapter and it should be recognizable.
Problems you might have:
  • Long time before boot (even if disk is set as bootdrive)
  • Finder shows it as external
  • Random freezes or restarts after hibernation
Your only option is to use SM951 AHCI (PCIe/mSATA instead of PCIe/NVMe) drive - MZHPV128/256/512 This one works as it should.
MacBook Pro/Air 2015 has no problem with M.2 PCIe/NVMe drives and you can upgrade it safe and works great ;)
Score 1
5 opmerkingen:
Most of these adapters create excessive CRC errors as such I really don't recommend them. I've had to replace quite a few with the correct drives as they tend to wear out from the excessive writes.
door
dan
now in 2019, is there a solution (a certain adapter that will work, etc) to upgrading ssd to the newer 970 evo pro or 970 evo plus in 2014 3.0 i7 macbok pro retina? or do u have a recommendation on another compatible ssd that is equal in speed and specs as the 970’s?
thanks
door
I still don't recommend using these adapters and M.2 drives.
In fact the newer Samsung 970 EVO plus has been having more issues in MacBook Pro's. This is all related to the differences of Apple's interface Vs the M.2 interface.
The assumption most have is the timing of the two interfaces is the same so the drives are interchangeable. Sadly thats just not true! While they are similar they are not the same.
Stick with a real Apple SSD or go with either OWC or Transcend there SSD's are matched to the interface unlike the M.2 drives.
door
Load of crap, there's no issues with the 970 evo plus providing you use the Sintech adaptor, other brand adaptors have quality and interface issues.
door
Right Mal Gee. I used to use OWC in a 2015 MacBook Pro. First one failed after 3 years and OWC replaced it gratis, however, that one failed this year and OWC said the warranty was from the date of the original purchase. Price difference between EVO 860 1TB and 1TB OWC was > $100 so I searched for an adapter and found Sintech. Bought it for $17 and bought the EVO 860 1TB. No issues from start to right now. I'd spend the bucks on a 2TB EVO 970 to get additional disk space on my MacBook.
door
Hi All, I'm trying to install a new ssd using an adaptor on a 970 Evo NVme m.2 500GB SSD to my macbook air 11 (early 2015), the disk utility did not detect the new SSD drive after I attached to it. I'm not sure what is the problem. I'm currently using OS X Catalina on my mac. Anyone can help?
2 opmerkingen:
get an external NVMe enclosure and initialise the drive first, then erase it, and clone your mac drive using CCC or Superdooper and copy to the new drive, then install it in your mac, be sure to disconnect the battery first before swapping the ssd!
door
@fixitdude74 - With the newer macOS's CCC often makes a mess of things! Best to stick with Apples Migration Assistant it works quite well!
door
Hello, I know this is an old topic. but hopefully someone can help me.
I have this:
macOS catalina
10.15.7. MacBook pro (retina 15", early 2013)
CPU: 2,4ghz intel core i7 de 4 nucleos.
RAM: 8GB 1600mhz ddr3,
GPU: intel HD graphics 4000 1536 MB.
I have seen some people that say that Samsung EVO 970 evo plus can be used with this mac, using sintech adaptor. Have someone use it in this early 2013 macbook pro retina?
My Macbook is getting slower, I dont need the 3500 mb/s from the Samsung... but at if my ssd now makes I guess aroubnd 500mb/s.. I would like to reach maybe 1000mb/s or more.. What is the best option? I dont mind to pay for a good drive or adapter..
There are adapters for M.2 (NVMe SSDs) to 12+16 pin (apple's connector). Just check that you get the right adapter, and you could plug in those blazing fast (and not so expensive) SSDs into your Mac.
https://www.amazon.com/Cablecc-16pin-Mac...
https://www.amazon.com/Samsung-970-EVO-5...
Score -1
6 opmerkingen:
You can't use a PCIe/NVMe drive in a mSATA based system!
door
Dan, I am bored and have some time in my hands, I would like to try the upgrade. my mac is the MacBook Air (13-inch, Mid 2012) 1.8 GHz Intel Core i5
which will be the adapter that I will need? will it be the same one as the one you posted above? thanks for your assistance.
door
I don't use M.2 adapters in my practice. I only use Apple OEM, or 3rd party SDD's by OWC or Transcend.
In my testing and seeing quite a few of these not working any more and having to replace the drive with the correct one, I don't recommend them.
door
no caso nos MacBooks 2015 funcionam sem problemas no 2013 e 2014 apresentam instabilidade
door
To use the samsung 970 EVO plus you will need the sintech adaptor(available through amazon), then get a NVMe M.2 enclosure that is compatible with apple (not all enclosures support apple), i chose ORICO TCM2-C3-SV, then used Superdooper to make a clone of my existing MacBook ssd.
door
1 commentaar meer tonen
Voeg je antwoord toe
jensfilstrup zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 28
Afgelopen 30 dagen: 106
Altijd: 44,710
