Ga door naar hoofdinhoud
4-inch iPhone released in March 2016 with similar hardware specifications to the 6S. Available in Silver, Space Grey, Gold, or Rose Gold with 16/32/64/128 GB storage options. Model: A1662 and A1723
1049 Vragen Bekijk alle
Phone keep restart after 2 minutes
Hi everyone..
I have an iphone 5sE, keep restarting after 2 minutes.
Phone boot perfectly, everything work well, but continue restart.
I change the battery , check with DCPS, the current absorbing is normal.
Any suggestion plz.
Thanks a lot
Is dit een goede vraag?
1 Opmerking
@refectio Thanks Minho.. i will try... :)
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Something is causing the logic board to restart. You could try by disconnecting everything and connecting only a known good battery and Lightning port. Then use a tool like 3uTools to see if the phone continues to restart. If it does, then you have a logic board issue. If it doesn't, then one of the connected modular components is the cause.
Was dit antwoord nuttig?
Score 3
Voeg je antwoord toe
AGS zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 63
