Ga door naar hoofdinhoud
The Airport Time Capsule is a wireless router and network-attached storage (NAS) device manufactured by Apple. Model A1409 is the fourth generation revision of the Time Capsule released in June 2011.
25 Vragen Bekijk alle
Airport not turning on, how to access data from the hard drive?
I believe a power surge took out the Airport Time Capsule power supply and the device is not turning on.
How do I go about accessing the data from the hard drive?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
To be able to access the data on the Time Capsule's internal hard drive will require that you remove the drive from the base station. Then place the drive in a drive caddy or enclosure. Finally, connect the drive to the USB port on a Mac or PC. For there, you should be able to access the drive.
AirPort Time Capsule Model A1409 Disco Duro Replacement
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
sunishtmathew zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 197
