Ga door naar hoofdinhoud
A1418 / EMC 3068 / iMac 18,1 / 2.3 GHz dual-core i5 processor. Released June 2017.
41 Vragen Bekijk alle
Does the 2017 21.5” Non-4K iMac have a socketed CPU?
Is the CPU on base model 2017 21.5” iMac EMC 3068 modular/socketed/removable as are the 4K models? I see info for 4Ks but not base model.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
I haven’t opened one yet so I can’t tell you from experience what it has. But doing a bit of sleuthing we can see the chip appears to be socketed!
Now the rub! If you are thinking you can upgrade this to the i7-7700 you won’t be able to as the 4K models use a different socket (FCLGA1151)!
Was dit antwoord nuttig?
Score 2
2 opmerkingen:
Thanks, Dan! I was indeed hoping to upgrade to the i7 7700. Between your news that socket difference and Adam O'Camb pointing out that (within a differnt question thread) the CPU is indeed soldered to the board on this model, I will have to change my plans. Can I put in quad core CPU and 32Gb RAM?
door
I guess I'm getting old, I forgot Adam's note.
door
Voeg je antwoord toe
Thad Crouch zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 282
