Ga door naar hoofdinhoud
Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Vragen Bekijk alle
Why can't I unlock my sim
i can't click on the "unlock" (or the "ok" for that matter) button when the "SIM locked" appears
theres nothing wrong with the screen
it ran out of battery and when it turned on i couldnt do it anymore
I've tried resetting it and hard reset AND I've already tried to remove and get back the sim slot
+ when i did remove the slot it shows up the "no sim card" message and I could not click on the "ok" option either
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
I had the same, looks like a part of the screen was no longer responsive.; just that part above the OK.. So by turning my phone to landscape I could bypass this..
Was dit antwoord nuttig?
Score 1
Hmm thats really wierd make sure your screen is fully seated again, or try reinstalling ios to your phone if this doesnts help try going to the apple store where they csn scan your device
4 opmerkingen:
I recently did a screen replacement but I've turned off and on my phone multiples times after that and they all worked fine. I have also resetted completely the device, the problem remains
door
Then i would highly recommend taking it to your local apple store to get more info on your situation
door
that's what I'll most likely do, however I've gotten it to work by going into settings>phone>SIM pin and disabling it
door
yah thats so weird! Apple will perform a full scan for free then you can pinpoint the issue and we can go from there
door
Voeg je antwoord toe
Inês Almeida zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 6
Altijd: 820
