Ga door naar hoofdinhoud
The iMac Pro, is Apple’s most powerful iMac to date. It comes with either a 3.2 GHz 8 core, 3.0 GHz 10 core, 2.5 GHz 14 core or 2.3 GHz 18 core Xeon W processor. EMC 3144 / A1862 (ID iMacPro1,1)
35 Vragen Bekijk alle
Alternate Replacement screws for VESA Mount Kit
Like many others, I've heard a few sparse stories about the issue of the mount Torx screws breaking without being able to validate it myself. I've successfully mounted then dismounted that kit once, and need to remount it in the close future.
I'm trying to find some high-quality replacement parts for these screws to avoid any potential issues-does anybody know what to order as replacement for these screws?
Or maybe I'm just overreacting…
Is dit een goede vraag?
Score 2
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
So that everybody knows, the screws that fit the iMac Pro Vesa mount are Metric 2.5 x 8mm
Was dit antwoord nuttig?
Score 3
2 opmerkingen:
Does that literally mean something like https://smile.amazon.com/dp/B012TE3LDM would work? Any considerations about needing the head to be low profile or similar? I'm buying an iMac Pro and want to avoid using the provided screws if they have the locking "glue" on them.
Or alternatively, if anyone has specific recommendations on a screw I can buy from iFixit or elsewhere, that would be great. I don't know if "steel" is good enough, or if a specific steel is needed for the iMac Pro's weight.
door
Did it fit Brian? Do you have a recommendation?
door
Het nuttigste antwoord
The older 2011 27” iMac VESA kit has stainless steel screws. I’ve not had any problem with the 20 or so mounts we used.
The newer iMac Pro VESA kit is using cheap soft steel screws! Don’t use them!!
Take one of the screws and the bracket to your local hardware store that sells screws you should be able to find a stainless replacement for a few dollars.
Still waiting for Apple to address the screw failure nothing posted on the support page as of yet, and my local Apple store still has them on the shelf with the original screws.
Score 5
1 Opmerking:
I was in the same situation Snazzy Labs was in, the screwheads broke off when I was turning them to mount my iMac Pro. Unacceptable by my terms.
door
Voeg je antwoord toe
stephan tran zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 26
Altijd: 3,857
