Ga door naar hoofdinhoud
Repair information and guides for the Apple iPhone 5s that was announced on September 10, 2013. Model: A1533, A1453, A1457, A1528, A1530, A1518
3530 Vragen Bekijk alle
iPhone 5s restart with showing red and blue lines
Hello
My iPhone 5s restart while using showing red and blue lines on the screen and then get stuck in the restart loop.
I have tried to reset, restore and even flashed the os of the iPhone but still, the problem doesn't resolve.
Can any one help me to resolve this problem.
Thanks
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Could be a damaged front camera cable, you will need to unplug it after unplugging battery then turn on the phone again after it is unplugged then battery plugged back in.
In most cases this is a board level issue related to a failing NAND flash memory chip (eMMC) or baseband chip going bad which is rare. In that case it would cost more than what the phone is worth making it not worth fixing.
Was dit antwoord nuttig?
Score 5
Mine goes that but instead of getting stuck in loop it restarts. It has happened twice randomly as far as I can tell. What is the problem with mine?
Voeg je antwoord toe
Akash Yadav zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 2,296
