Ga door naar hoofdinhoud
MacBook Pro modellen met 13" Retina beeldschermen geproduceerd begin 2012.
4681 Vragen Bekijk alle
Wi-Fi icon won´t show up
I have a MacBook Pro A1502, the wifi icon dosen´t show up, I´ve changed the wifi card and still the same. the Bluetooth is also damage. When I change the card for another one the bluetooth appear, but the Wi-Fi still disable, I can´t start nor create the service throught the terminal, it says that there is no Wi-Fi device. HELP PLEASE!!!
I also try to enable the wifi network service in the terminal but the listallnetworkservices command doesn´t show any wifi interface
Is dit een goede vraag?
1 Opmerking
The A1502 covers quite a few different models! Can you pick yours from this listing: A1502 systems
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
I’m suspecting the I/O cable needs to be replaced. Here’s the IFIXIT guide for the 2014 model: MacBook Pro 13" Retina Display Mid 2014 I/O Board Replacement and here’s the needed part: MacBook Pro 13" Retina (Late 2013-Early 2015) I/O Board Data Cable but without knowing your exact system I’m just guessing here.
MacBook Pro 13" Retina (Late 2013-Early 2015) I/O Board Data Cable Afbeelding
Product
$9.99
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Luis Anniel zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 137
