Ga door naar hoofdinhoud
iPad Air Wi-Fi + Cellular, model no. A1475. Available in Space Gray or Silver, with 16/32/64/128 GB configurations.
flex charge for ipad Air
Hello guys
i have 2 ipad Air with charging problem .... port was dirty only i wanted to change port but does,nt work ... i changed 3 flex and IC U2 and everything is ok ... i dont now whats wrong !!!!
we have difrence flex charge for ipad Air ???
thank you
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
The charge circuit on the iPad Air consists of the charge port, the Tristar IC and the PMIC. If you have changed the charge port and Tristar and are confident that those replacements went well, the only other option is a defective PMIC. Keep in mind that the PMIC is insanely expensive.
Was dit antwoord nuttig?
Score 2
If you are using the correct / matching model for the iPad for charging port assembly and Tristar then it should be pretty much the same.
If port is dirty you could of just tried cleaning the inside of the port first which sometimes fixes the problem where you have to wiggle it to charge.
If any charging port pins pushed down it can most of the time be fixed by careful cleaning under microscope.
Score 2
Voeg je antwoord toe
karo zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 209
