Ga door naar hoofdinhoud
AC power adapter for MacBook, MacBook Pro, and MacBook Air. Uses a self-aligning magnetic connector that disconnects safely when tugged. First-generation (2006-2012) MagSafe chargers have a slightly thicker, L-shaped connector. Available in 45 W, 60 W, and 85 W versions.
65 Vragen Bekijk alle
MacBook magsafe dc power supply adapter voltage
When hooked up to a dc power supply. My adapter shows the exact voltage that the power supply is putting out. If i load it with 16.5 volts when checked with a multimeter when it's not connected to a mac it shows 16.5 volts. Is this normal or is it supposed to be 6 volts then 16.5 volts when a load is applied? It's magsafe 1 L type connector. The connector sense is 1.7 volts.
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Apparantly when connected via dc power supply it is always outputting 16.5 volts to the charger tip. However when connected via the apple psu block it looks like it supplys 5 volts then exactly 1 second later it ramps it up to 16-18 volts to avoid sparks.
Was dit antwoord nuttig?
Het nuttigste antwoord
Review this article: Macbook charger teardown: The surprising complexity inside Apple's power adapter it should help explain things.
Score 2
Voeg je antwoord toe
Michael Mulliken zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 10
Altijd: 981
