Ga door naar hoofdinhoud
Released June 2012 / Core i7 processor with Turbo Boost / Up to 1 GB GDDR5 Video RAM
597 Vragen Bekijk alle
Mac boots to folder with question mark. Disk utilty does not see disk.
Mac will not load. Disk utilty no longer sees the disk.
However, when I load a windows installer usb flash drive on the Mac. Windows installer can read the drive using the Mac?
I was thinking it has to be a cable issue. This makes no sense.
Drive works perfectly plugged into another Mac.
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Could be your HDD cable, try an other cable and see if it works
Was dit antwoord nuttig?
Score 1
2 opmerkingen:
Ordering a new cable now. Drive does work in another macpro. I just didn't understand why windows installer could see it and even format it if something was wrong with the cable. I guess windows usb installer bypassed mac post and that one pin is messed up on the cable. Idk.
door
Yes, your HD drive cable is bad! This is a common issue.
Before installing place some electricians tape on the uppercase where it crosses over as the rough surface the aluminum tends to damage the cable also don't over bend the cable as the thin wire traces can get damaged.
door
Voeg je antwoord toe
Jeremy White zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 4
Altijd: 61
