Ga door naar hoofdinhoud
The Nissan Altima is a mid-size automobile manufactured by Nissan, and is arguably a continuation of the Nissan Bluebird line, which began in 1957.
Cranks and Starts Sometimes
My 2006 Nissan Altima has been cranking and starting but sometimes it would just shut off while I'm driving. Now it will only crank and not start. Someone said I may have a bad fuel pump. How can I find out what the problem is? Are there other things that I can check first since a fuel pump is so expensive.
Is dit een goede vraag?
2 opmerkingen
Hi @gulfport152 ,
Get the OBDII port scanned for codes using a scantool.
Any codes shown will give an indication of what is going on in the engine
door
Thank You so much
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Its most likely the fuel pump. Grab a friend and have them try to start it while you beat on the gas tank. Sometimes that will get the fuel pump to kick on. If it does you will know its a bad fuel pump? You also mite be able to hear it by turning the car on without cranking it.
Was dit antwoord nuttig?
Score 1
1 Opmerking:
I started this morning, but I did get someone to check it out and they believe that it is the Fuel Pump going bad
door
Voeg je antwoord toe
R. Sumrall zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 2
Altijd: 398
