Ga door naar hoofdinhoud
De Sony Cyber-shot DSC-H300 20,1 megapixel camera wordt gebruikt voor het maken van foto's, 3D-beelden en video's. Modelnummer: DSC-H300. Het modeljaar van de camera is 2014.
Won’t turn on properly
I recently purchased a Sony dsc-h300 camera online from someone (I know kinda stupid) when i got it, it worked fine I took about 7 pictures then I was getting a turn off/on warning pop up. I turned it off then on and it worked fine. The lens is out like when you zoom. The camera all of a sudden shuts off with the lens still zoomed out. I turned it back on and it just shows the cyber shot logo and won’t turn on like it normally would. I changed the batteries, blew the lens, held the power and menu button even tried power and okay button also i had hit it and I still have the same problem. If anyone knows how to fix it please let me know.
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Filteren op:
Het nuttigste antwoord
Hi Grace
Most likely a battery problem.
The AA batteries must be of good quality and the battery contacts must be clean.
This camera is also equipped with a built-in, rechargeable battery to keep track of the date and time as well as other settings, regardless of whether the camera is switched on or not.
This rechargeable battery is constantly charged while using the camera. However, if you only use the camera for short periods, this battery will gradually become exhausted. If you do not use the camera at all, the battery will be completely exhausted after approximately one month. In that case, you must charge the rechargeable battery before using the camera.
Even if this rechargeable battery is not charged, you can still use the camera, but the date and time are not displayed.
Charging method for the built-in, rechargeable spare battery
Insert batteries with sufficient remaining charge in the camera, and then leave the camera switched off for 24 hours or more.
If the built-in, rechargeable spare battery is defective, it can also cause problems.
Good Luck;
Homer82
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Grace zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 13
Afgelopen 30 dagen: 36
Altijd: 2,719
