Ga door naar hoofdinhoud
Apple Watch Series 2, announced September 7th, 2016 and released September 16 2016.
20 Vragen Bekijk alle
Replaced Apple Watch 2 screen will not pair now
I replaced my Apple Watch 2 screen with a screen I got from Ifixit. I pair the watch with my phone it is paired for a moment but then get the message that the pairing failed ??? Any ideas?
Is dit een goede vraag?
Score 4
Voeg een opmerking toe
17 Antwoorden
Het nuttigste antwoord
I’ve been having a lot of issues with this as well (Series 2 iWatch). Trying to restart the phone and iWatch but to no avail. I think switching out the screen will help but in my situation the old screen was non functional (the display was completely out). I’d thought I try something crazy and it worked! I attached the two ribbons (closest to the digital crown) to the new display, then I attached the last ribbon (furthest from the crown) to the old display. After doing this the watch paired after the first try. Hope this helps some people. It was really frustrating looking for solutions all over the web but this worked like magic.
Was dit antwoord nuttig?
Score 12
10 opmerkingen:
Wow, man.
It really works like a magic. I thought that you are joking but decided to try because I wasted my satturday morning for "dances" with Apple Watch 2 with a new screen. I tried all described above before I tried your method.
Your method worked wor me after the first try.
I'm so grateful.
But its interesting - if I will erase my Apple Watch with new screen connected - will the connection error reappear?
Thanks
door
Will this work with any original apple watch series 2 screen or does it have to be the one that came with the device before it was replaced? I have a series 2 watch that was still paired to a device before the screen was replaced so after the repair it worked fine until the device was unpaired and tried to pair it to a new device so I do not have the old original screen available.
door
Hi! Only ! with the device before it was replaced.
door
John Lee ! Thank you! I did it! How did you come up with that?:))
door
keep you old screen in a safe place if you need to repair again in the future
door
5 commentaren meer tonen
Dit antwoord was oorspronkelijk aan een andere vraag gericht.
Hi.
I have testet a lot around this issue now and finally got it to work.
Here is what I’ve tested:
IOS 11.3, 11.4 and 12 NOGO with new screen.
Switched back to the old screen, was able to pair. Updated watch to 5.0.1 . switch screen and still OK. Factory reset on the watch and still able to Pair. So to all: Upgrade watch before switching screen!
Score 3
4 opmerkingen:
Thanks Anders. Does anyone know how to update iWatch (after LCD replacement) without the old screen?
door
Would also like to find out if the watch can be updated without the original screen?
door
how can you upgrade watch when screen is broken?? Cant see squat!
door
@pjmfr
you only need the nfc module from the old broken screen.simply connect this module with the appropriate ribbon cable and the other ribbon cables can be plugged into the new screen. if it is too tricky, you can also remove the nfc module from the defective screen with hot air (100 C), because it is only glued. i was able to remove it quite well with a narrow, sharpened spatula and some hot air of 100 C.
door
The same thing happened to me. If you look at the other questions on this forum, you’ll find two other examples of exactly the same problem. Unfortunately no one here seems to have a fix. On another forum I read that the watch has to be reprogrammed using IBUS S2, but this adapter + software costs a fortune (more than 100 USD each for adapter and software).
Score 1
1 Opmerking:
I really wish there was an easier fix for this
door
Martin after I fixed the screen and it would not pair I took it to an Apple store ( innocently not acknowledging I had replaced the screen ) they ? Zapped under limited warranty. Bingo it’s fixed
Score 1
1 Opmerking:
Hi did they replace it or what did they do ?
door
yup, same here. watch series 2 4.2.something firmware, ios 11.4 iphone firmware.. seems like thease cases will begin to pop up. Unfortunatley I have had no luck in figuring this out. Some say, that by flashing by ibus s2 could fix the issue but unfortunatley there are no ISPW firmwares for apple watch s2 anymore that are being signed by apple.. so not an option here...
However: IF you attach the original screen, pair the watch and then switch to the new screen the watch will work ( more or less... it won't update to 4.3.x complainig about update that could not be verified and of course if you erease you won't be able to pair again...)
Still hoping this is a bug somewhere... and either ios 12 or watchos 5 will fix it and I'm being positive that apple does not want to screw us all..
Anyway..guys.. would be helpfull if you could try to pair with an Iphone running FW 11.3.xy
Score 1
you must pair your phone first with the broken screen ,,then replace the broken screen with the new one you purchased,its the only wayalso,, keep your old screen just in case you get a new phone or need to repair again in the future.
Score 1
2 opmerkingen:
How it works if old screen is damaged?
door
@Gadget Garage
door
The exact same thing happened to me! Have you figured out how to solve it? I disassembled my watch again and reconnected the screen just in case it was connected wrong the first time, but it did not help. I am most thankful for help. Right now the watch is useless, which is frustrating considering the expensive replacement LCD.
I’m having these issues also. I’ve done everything correctly but after you for some reason unpair it after the screen repair it will no long pair. I have about 3 now that have done this out of 20 repairs. I know everything is assembled correctly so I don’t not understand.
Exact same problem and have not resolved it. Went to Apple store and was sent off. They probably won’t fix it but hope something good will come from it.
4 opmerkingen:
I'm still having the same issue. I actually bought a iBUS s2 to try and flash software back onto the watch but I haven't really had time to play with it yet. So in the mean time i've got 3 watches now with this issue. :(
door
Hi. Sorry to say this but as I have already figured out..ibus s2 wont help you unless you have a apple watch signed firmware for the apl watch 2..
door
Has Apple sent it back or able to fix it?
door
i have ibus too but no firmware... cant buy the MfC DONGLE
door
Someone wrote that IOS12 might solve the problem, but I now installed the IOS12 beta 3 and tried to pair the series 2 watch. It did not help a bit - it was exactly the same error message that I have got all of the time since the display shift.
Anyone tried WatchOS 5?
2 opmerkingen:
Is it still not working?
door
Sorry but no progress. I tried again today with the sharp iOS12 (after the Watch OS 5 release) but the pairing problem is still there. However, if just OS5 firmware becomes available for re-flash then all could be solved with iBUS.
door
Hi. I have replaced the screen in my Watch 3 LTE, because Apple didn’t wanted to give repair/replace service for it, even willing to pay for it, because I bought it in France, and I live in Spain… They have an european warehouse that serves all countries here, so they could send the replacement to any country, including Spain or France. Well, in the Apple Store of my hometown Valencia, couldn’t do it because the LTE version is not yet being sold in Spain, neither helped the Apple Care phone service. That’s the worldwide service that the biggest company in the planet offers.
So I had no choice but do it myself. The new screen works perfectly, colors, brightness, touch sensor and force touch sensor, all. But the watch does not pain again with the phone, with the same error message from above. Anyone has a solution or a clue of what to do?
5 opmerkingen:
Any updates to this? I have the exact same problem. Watch was working great with the replacement digitizer/screen until i tried to update to Watch OS 5. Now it won't pair with my phone!
door
Any updates?
door
Here, i had to place the OLD original screen to sync, it wont pair with the new screen, just the old one!
door
What will happen if u cant find the oroginal old screen>
door
Many people have this question. Screen broke, replaced the screen, old screen is gone, can’t update watch OS because it won’t pair with iPhone. Is there ANYTHING that can be done??
Can a functioning, original (but not MY original) display be connected to my watch body, pair to my iPhone, update watch OS, then switch to the replacement display as described above and it work? Any thoughts?
door
Any news about the previously problem? My old scratched screen doesn’t work at all.
Hi Guys,
I have picked up that if the screen you are trying to use is not truly an original screen then you will run into this pairing issue. I work at a repair centre in South Africa and I had a few of these Apple Watches come in with this issue after we had replaced the screen. Only when I tested the watch with a new ORIGINAL screen then they would pair it with an iPhone.
2 opmerkingen:
So that means that if you lost your old screen. Buying a used, cracked original screen from Ebay or whatever will fix the problem with the solutions I mentioned above?
door
My new screen is used from another Apple Watch S2 but I have the problem again.
door
I also had the problem, that my Apple Watch did not pair, after replacing the screen.
But it was very strange, since the watch did pair at first. Then I was not able to add my credit card via Apple Pay or update to wOS 5.2.1 (from 5.2) and so I unpaired the watch, hoping that it would work once pairing it again.
Unfortunately it would not pair again at all.
So I opened it after reading this thread and figured out, that the GPS modules connector was loose and just fell of the display, when I touched the cable.
So connecting the (not working) display from another watch made it pair and upgrade again but still I am not able to add Apple Pay. I guess that it recognises the GPS module and since it is wOS 5 it works even though it is not the original GPS module. But I think, because it is not properly connected to all three cables of the display the GPS maybe is not able to fix a location which disables the Apple Pay function out of security or licensing reasons.
2 opmerkingen:
i've read that one needs to get an original apple watch display to use apple pay again. because the gps module or whatever apple play uses is fixed to the original display. so when u swap it, the system wont accept the new display for apple pay..
door
Same with my spple watch 4 cracked screen.I mounted new screen from aliexpress.Won’t update.So i reset the watch.Won’t pair at all.I did it 30 or 40 times.So,my watch was under warranty.With the new screen non original,touch ok,screen ok,but no pairing,i went to genius bar,and they,without check if my creen was original or not,they gave me another NEW apple watch
door
Can anyone find the solution without original screen?
I’m from India I purchased a cracked US version Series 4 GPS Apple Watch, I replaced with new screen unfortunately yesterday I did erase all contents on my Watch and unpaired it with my iPhone now while pairing it I’m not even any pop up message like pairing failed
How to fix this issue in my county no Apple Pay in this case what is solution to pair it again?
You help is appreciated, Thanks
2 opmerkingen:
I had the same issue, I don’t know if it’s too late but I’ve posted a workaround that worked for me
door
this pairing issue appears when you use LTE screen on GPS version screen or vice versa. Just be sure you use the correct LCD (GPS version lcd are more expensive)
door
I had the same issue after replacing the screen of a Series 2 (on WatchOS 5.1.3) : impossible to pair it with my iPhone 7 (iOS 13.3.1).
I have just found an alternate solution, using my old iPhone 6 (on iOS 12.4.5) : it didn’t ask to update the watch for pairing and succeeded to pair on my first try !
I then updated the watch manually, to watchOS 5.3.6, unpair it and pair it to my iPhone 7 successfully !
My theory : an old iOS version can pair a watch with an old watchOS and be used to update the watch.
Can any find solution
how to pair Apple Watch without original screen
Voeg je antwoord toe
Tom Jacobs zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 5
Altijd: 854
