Ga door naar hoofdinhoud
The Sega Game Gear portable gaming device was released in 1991 in competition with the Nintendo Game Boy.
41 Vragen Bekijk alle
Vertical coloured lines no sound
Hi
I'm having trouble with my Sega Game Gear. When the unit is powered up the red power light illuminates however the screen only displays verticle coloured lines across two thirds of the screen from the left. The remaining third is black. There is also no sound.
Any idea what the problem might be ? Is it repairable?
Thank you
Regards
Mustafa
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
I would guess this is also a capacitor issue, or possibly a bad LCD screen.
You should try it out with other games as well of course.
Capacitors go bad over time and they affect screen and sound and needs to be replaced.
You can find good guides now if you google it, does require solvering thought.
Was dit antwoord nuttig?
2 opmerkingen:
Thank you Erik, I'll try changing the capacitors.
PS I have tried other games it's exactly the same...
Thank you once again
Regards
Mustafa
door
Your welcome, Good luck with the cap change!
door
Voeg je antwoord toe
Mustafa Desai zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 22
Altijd: 1,810
