Ga door naar hoofdinhoud
Early 2011 Model: A1278 / 2.3 GHz i5 or 2.7 GHz i7 processor
782 Vragen Bekijk alle
Magsafe light stays green , not charging.
Hi,
My MacBook Pro battery is not charging when I connect the MagSafe charger, the LED is slightly green and it does not charge my battery. I have reset the SMC and there is no change.
My battery died so I bought a new battery it has 70% charged so my system booted up so I can reset SMC, but when I connect it to MagSafe the light on it goes to green and not charging. The battery icon on top when I click say not charging.
I disconnected the battery, and then plugged in to MagSafe adapter alone the LED on it still stayed green and in this situation. I can't even turn on my system, it turns on for few second then turn off.
I tried second MagSafe power adapter, nothing changed.
Does any one know of the solution?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
The charging logic on the logic board has a problem. You'll need to find someone who can fix it or replace the logic board.
Was dit antwoord nuttig?
Score 3
4 opmerkingen:
I change the charging logic on the logic board ( replace it)
But this time mac boot without battery just plugged in to power
Nothing change the same as before its not charging battery only green light
door
Can you explain more fully... What did you replace?
door
I replace board power
This one:
https://iranfso.com/image/cache/catalog/...
door
Thats the DC In-Board and does not effect the charging logic.
The logic is on the main board. Review this vid: How cheap eBay batteries DESTROY Macbook logic boards!
door
Voeg je antwoord toe
kaveh zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 12
Altijd: 8,629
