Ga door naar hoofdinhoud
Released September 16, 2016. Models A1661, A1784, and A1785. Available in 32, 128, or 256 GB configurations in Rose gold, gold, silver, black, jet black, and (Product)Red.
20 Vragen Bekijk alle
My water damaged iPhone 7 plus wont turn on
Hi. My iPhone 7 Plus fell in the pool and I dried it .
When I tried to switch it on, it showed the apple logo and then the screen just goes dark and then back to the apple logo in loop. It just wont turn on. Please help:(
Is dit een goede vraag?
Score 8
3 opmerkingen
how to fix your iphone 7 when half of the screen isn’t working?!?!?!?!?!?
door
Hi good afternoon everyone. My name is Oluwakemi Deborah Ayo-Oladapo. My iPhone 7 Plus fell into hot water in my bucket and my iPhone finger print refuse to work. Please I need help, what should I do to make it work?
door
Hi Im Caitlin Nichols and I recently went to a waterpark I had an Iphone water case on but somehow my iPhone still got wet a little bit and when I tried to cut it on it is just showing the apple logo and going back off what should I do I blew all of the water out,i put the it in front of a fan but it still doesn't work.
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
With water damage, you have to decontaminate the logic board before doing anything else, otherwise there will be latent issues down the road.
Not every water-damaged phone is recoverable and depending on the kind of liquid (salty, dirty, filthy), sometimes the success rate is quite low. That said, IMHO, it's always worth a try otherwise we are just piling up the e-waste.
The water is inside the phone, on the logic board and under the shields, even under the IC's. The real problem is the mineral deposits that can cause short circuits or the corrosion that is taking place as the water evaporates. Leaving the power on the device accelerates the process. The longer you let a phone sit, the more time you are giving corrosion to damage your logic board. The saltier or harder the water is, the more damage will occur. The water needs to be displaced, not evaporated.
  • Open your phone and remove the logic board (follow this guide)
  • Inspect the logic board, especially around the connectors and look for corrosion.
  • Inspect both sides of the board. Unfortunately, most of the board is covered in shields. That's usually where the damage is occurring.
  • Put your board in a container with >90% isopropyl alcohol and let it sit for a while.
  • Use a soft brush, like a toothbrush and lightly brush away any corrosion you see.
  • Rinse in alcohol and repeat.
  • Let it air dry for a day.
  • Re-assemble and hope for the best.
You should also replace the battery if it has swollen. Resist the temptation to pop it to let the gas out. A compromised Li-ion battery is a fire hazard. If the device appears to power up but behaves erratically, then use a tool like 3uTools to flash the firmware as it may be corrupted.
A professional repair shop that does water damage repair may be able to recover your phone or the data because they have access to pro-level ultrasonic baths and specialized cleaners as well as the skills to troubleshoot your board. Many shops have a no fix/no fee policy so you don't have to spend money to find out if the phone is fixable or not.
Was dit antwoord nuttig?
Score 4
2 opmerkingen:
I dropped my iphone 7 in the toilet for like 30 seconds. it was working afterwards, but the touch screen wasnt working, so I was tapping my phone on the palm of my hand, then the rainbow thing, with the coloured lines and stuff showed up then it turned off and wont come back on.
door
I dropped my phone into swimming pool then after wards the middle screen is not working any suggestion to how to fix my phone not to in technical help me
door
Voeg je antwoord toe
Sarah zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 47
Altijd: 37,933
