Ga door naar hoofdinhoud
Formally called the Chevrolet C/K, C/K is a series of trucks manufactured by General Motors and marketed under the Chevrolet and GMC brands. The C/K line includes pickup trucks, medium-duty, and heavy trucks.
299 Vragen Bekijk alle
issues with car electrical system
Help..I'm not sure what's going on..first off I have a 95 chevy 2500..both the brake light n abs light was on when got it..I plugged in wire for trailor hitch n pressed brakes to check lights n popped fuse replaced #1 brake fuse but it kept popping..so I unplugged the trailer hitch wire for lights..replaced fuse again..it worked this time so I decide to take truck up the road I got about 2 blocks from my house n smoke started coming up around the steering wheel..smelled like wires melting..I haven't a clue..I just changed the fuse that's it..any ideas..
Is dit een goede vraag?
Score 1
2 opmerkingen
It melted the wiring harness to the brake light switch..
door
Headlights went out.
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Definitely a short circuit. Now where it is I'm not sure.
Was dit antwoord nuttig?
Score 1
1 Opmerking:
short in the switch itself try replacing it
door
Voeg je antwoord toe
John Faust zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 12
Altijd: 339
