Ga door naar hoofdinhoud
The Huawei MediaPad M2 is a full-sized Android tablet released in February 2016. Includes models M2-A01W (Wi-Fi only) and M2-A01L (Wi-fi/3G/4G).
4 Vragen Bekijk alle
I can do with the error that I met on my device in CorelDraw?
Recently, I did not fail to complete important work. Several files opened in CorelDraw with errors - a valid workpath path was not found. And I have no idea how this could happen. I hope for your help. Perhaps someone here has already met with a similar problem.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
There are many variants of coreldraw file recovery, but the most easiest are the following...
By guide
Corel makes a .BAK backup file that has the same name and is usually located in the same folder as the original file, but can also be located in the /Programs/Corel/Programs/Draw folder.
When a file is corrupted or otherwise damaged, find the .BAK file, open it, and copy it (save as) over the original corrupted file.
Or by articles, tips, etc...
https://support.corel.com/hc/en-us/artic...
Was dit antwoord nuttig?
Voeg je antwoord toe
NoelleFoley zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 39
Altijd: 367
