Ga door naar hoofdinhoud
This product is a 27-inch LED display with a resolution of 2650x1440 pixels released by Apple on July 27, 2010. It has the model number A1316.
78 Vragen Bekijk alle
How I can set-up 2 screens to my MacBook Pro
Sorry, I keep asking questions. But Mr Mayer is the guru. Without him I would have spent a fortune. And that fortune would not have solved the problem. Strongly recommend Mr Mayer.
Can you advise how I can set-up 2 screens to my MacBook Pro. The first being the display (it only has 3 USB ports, no HDMI) and a monitor with VGA and HDMI ports. Note: The MacBook does not have a HDMI port. Any advice.
Links to parts to purchase would be perfect.
Thanks again. You have saved me from spending a fortune.
Is dit een goede vraag?
3 opmerkingen
Please tell us exactly which MacBook Pro you have. Thank you for the kudos ;-)
door
Hi, thanks in advance for your help. I have a MacBook Pro A1286. Linked to a Tbolt Display A1316 (only USB connections) and an Asus monitor with HDMI and VGA connection. Hope that you can help. Thanks again.
door
Hello. Can I reach Mr Mayer here? You gave me great information about my tb display screen. I still need to find the right solution. Shall I post it here or screen comes on and then off
Thank you
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
the older macbook pros require a mini displayport adapter, for the one with vga, you will need this: https://www.apple.com/shop/product/MB572... and for the other one, the usb ports are for data, not video, it might not even be possible to use two screens on your model, and that other one would require a mini displayport cable, which should have been included
Was dit antwoord nuttig?
Score 1
1 Opmerking:
Thank you for your help. I already have the adapter. It works fine when my Mac. It also works fine with the Mac display cable. Is there an adapter that holds both so that I can share screens, an adapter for two Mini Display Ports for the MacBook. Maybe the model is too old to support this. Thanks
door
Voeg je antwoord toe
Fm34b zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 3
Altijd: 109
