Ga door naar hoofdinhoud
Repair information and guides for the iPhone 6S Plus that was released on September 25, 2015. Model A1687, A1634
1041 Vragen Bekijk alle
Replaced iPhone 6S Plus charging assembly
Hello, I recently replaced the charging and auxiliary port assembly on my iPhone 6s plus using third party replacements parts. After replacement, the charging port works (the reason I replaced to begin with) however my auxiliary port plays out only the right half of the output. Is this due to a loose connector or faulty part? I've already tried wiggling the aux cord around to try and get contact for full audio but I don't even hear a partial buzz to indicate it's possible. Thanks!
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Hello!
Chances are the part is faulty. Aftermarket chargeports have a high defect rate, as so many functions are controlled by this flex. I recommend purchasing an original flex off ebay that was pulled from a working iphone. I've never had any issues with a used original part.
Was dit antwoord nuttig?
Score 1
2 opmerkingen:
%#*@! I had guessed that was the case, I didn't even know their was a market for used parts though so I'll look into it, thanks man!
door
No problem! Doesn't hurt to double check and make sure your aux cord works fine with other devices
door
Voeg je antwoord toe
Solomon DellaPenna zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 3
Altijd: 77
