Ga door naar hoofdinhoud
Windows 10 is een hoofdversie van het Windows-besturingssysteem. Het werd uitgebracht in 2015.
Why I can’t login my Lenovo
I need help my Lenovo have a problem I put in my password and I wait a long time and I got in then the right hand side corner says that cannot login user and says I need to check something but I can’t use the power shutdown switch in there or even general and I tried a few time to restart it and every time when I got in it just says cannot login user and computer will restart in 1 minute
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Are we dealing with a laptop or tablet ? Either way we want to clear the boot memory to get a clean start up so to do this we want to drain all power from the device . . If were on a laptop remove the battery and power cord and once you 've do this then hold the power button down for 60 seconds . Then replace the battery and restart the computer . If your battery is internal then just remove the ram from the laptop and leave it out for a few moments. This will allow for a clean boot If its a tablet then simply disconnect the battery for 5 minutes or so. This will do the same thing . If this brings no joy then lets boot into safe mode and see if were dealing with a computer virus . for this I will need to know the exact make and model of laptop or tablet . Hope this helps if not let us know what(you device) you have and we'll try something else
Was dit antwoord nuttig?
Score 4
3 opmerkingen:
The thing is that my one is laptop and is can’t connect to window service and I can’t do anything I can’t search or use general
door
I can’t connect to windows or anything it won’t let be sign on
door
I already know I have a virus but, I havent run it
door
I have the Lenovo Laptop device
Voeg je antwoord toe
Tony zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 24
Altijd: 8,173
