Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
Deze laptop werd uitgebracht in september 2010 en is herkenbaar aan het modelnummer Inspiron N5030 of Inspiron 15. Het is een volledig zwarte laptop met een DELL-logo in het midden van de bovenste bedekking, een touchpad met gescheiden linker- en rechterknoppen, en een schijfstation aan de rechterkant van de computer.
The computer will just not boot
Hello,
The computer will just not boot.
Tried loads of trouble shooting with some stuff found on line.
Set to boot from external USB, but it does not seem to "pick it up" and just sits there.
Could be it that the version of the Windows for booting on the USB must be a "bootable"version?
Thanks if anyone has any ideas-
G-
Is dit een goede vraag?
1 Opmerking:
If i remember correctly it must be bootable version. If it's not bootable it will be behaving like any installer (which you must be already booted). I recommende you get a bootable windows and check connections of your ports with motherboard (if it's soldered) if it's still not detected.
door Deel
Voeg een opmerking toe
1 Antwoord
Filteren op:
You'll need a USB that's correctly formatted, and has a bootable version of the desired operating system.
Most importantly, you'll need to ensure that your BIOs are set to boot from a USB drive.
(If you're running off a solid state drive, with Windows 10 in particular, it can be tricky to get to the BIOs menu -- fortunately, that shouldn't be an issue with the system you're using, unless an SSD was installed afterwards)
You can also diagnose certain issues and troubleshoot by using a bootable toolkit, in order to see if there's damage to the hard-drive or file system.
However, if you never see any text display on the screen during boot-up, then it's likely to have much more extensive issues than just the operating system, or hard-drive.
Best of luck.
Was dit antwoord nuttig?
Voeg je antwoord toe
Gail Soberman zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 8
Altijd: 819
