Ga door naar hoofdinhoud
A 10.1 megapixel digital camera that has a 3.6x wide-angle lens, providing a wide field of view for panoramic pictures. It is also waterproof to depths up to 10 m (33 ft), freezeproof to temperatures down to -10°C (14°F), shockproof from heights of up to 2 m (6 ft) and crushproof up to 100 kg (220 lbs).
5 Vragen Bekijk alle
showed red alert while using in water, now does not turn on
while using camera in water, it stopped taking pics. and showed "door opened" on it, even though battery door was shut, now it doesn't turn on. How do I know that it may be just the battery that may be damaged?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Possibly a faulty seal or door catch. Open and remove all memory cards and batteries. examining closely for any sign of water inside the camera. Cut some thin card (cereal packet type) or paper into a strip. Gently and slowly insert the card/paper into the openings and try and get to all the corners. When you remove it look for damp patches on the card/paper. If it happened recently there will still be moisture inside. If there are any signes of water use the same technique for drying moblie phone you'll fine posted elsewhere. If you manage to get it working Don't use it in water again unless you manage to find the fault and fix it.
Was dit antwoord nuttig?
Voeg je antwoord toe
judmar36 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 9
Altijd: 138
