Ga door naar hoofdinhoud
De GoPro Hero3 White, die dezelfde afbeeldingssensor gebruikt als de originele GoPro Hero, werd uitgebracht in 2013 en was op dat moment de goedkoopste toegang tot de GoPro-cameramarkt. De Hero3 was een 30% kleinere en 25% lichtere actiecamera.
SD Card/SD Slot possibly Burning.
Hi
I wonder if you could help.
I have a GoPro Hero 3 white edition. I’ve had this for 3 years and its been great.
However tonight I was at my band practice filming like I normally do. I noticed that the front screen was stuck on 1min 54secs recording and wouldn’t stop. I then took out of the plastic case and noticed it was really hot. I took the battery out for a couple of seconds then put it back in. The camera powered up fine, but it said no SD card.
So I went to take the SD Card out and it actually burned my finger. I noticed that there was like a TCP smell on the SD Card and in the SD slot.
I’ve since waited about 2 hrs before turning the camera on. After 2 hrs I powered it on a almost instantly the SD card/slot gets seriously hot! I’m quite worried as I don’t want it to catch fire.
The Gopro has worked brilliant over the 3 years i’ve had it. I don’t know what would be best to do?
Can you help please?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Matthew,
I would not recommend turning the camera back on with the SD card installed in the camera. Take out the SD card and try powering the camera on without it.
If the camera turns on without the SD card installed your SD card likely failed in a manner which would cause a short circuit, and in that case it is likely completely dead.
Hope this helps,
Charlie
Was dit antwoord nuttig?
Score 1
1 Opmerking:
Thanks Charlie, I will give that a go tonight! :)
door
Voeg je antwoord toe
Matthew Trawford zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 9
Altijd: 586
