My 4 burners not working
the 4 burners on my ge stove do not work the oven and clock work
Is dit een goede vraag?
The answer really depends on if it is gas or electric. Here's a shot in the dark:
If the top burners do not work, but the clock does work, your appliance may be wired improperly, contact your installer for further assistance.
Check circuit breakers/fuses and power cord. On most slide-in and free-standing ranges, it will be necessary to pull out the lower drawer to access the plug and verify is connected securely (for others, sliding the appliance out from the wall would be necessary). If the power cord is connected securely, your oven may be wired improperly.
On coil burner models, check the burner. If one burner doesn't heat, remove it and plug it into another burner receptacle of the same size. Then, turn on that element. If it still does not work, the element will need to be replaced.
Was dit antwoord nuttig?
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 10
Altijd: 1,170
2 opmerkingen
What is the model number of your GE stove?
door Tim D
Mod. no. is jcbp350dt2ww thanks it is elect. the oven and clock works one day it work the next day it didn't it work for 5 years.
door mark aqwa
