Ga door naar hoofdinhoud
4-inch iPhone released in March 2016 with similar hardware specifications to the 6S. Available in Silver, Space Grey, Gold, or Rose Gold with 16/32/64/128 GB storage options. Model: A1662 and A1723
1049 Vragen Bekijk alle
iPhone SE boot loop after already repaired water damage
Alright, as you might suggest by the title, this is a problem that came up about a month after the first 'accident', so let me get you up to date:
-fell into river with my Iphone SE about 1 month ago (stupid, I know)
-Phone was submerged for ~30sec-1min in my pocket
-screen had lines over it and it had noise coming from the speaker and it shut itself off after a couple of seconds (power button not working anymore)
-dried it and put it in rice for 3-4 days
-not turning on, so I opened it and cleaned the motherboard and all pins with isopropyl
-left opened to dry for another 2 days and changed the WIFI antenna because I ripped a cable (stupid again, I know)
-Closed it up turned it on, working perfectly besides the power button not working and some tiny water marks on the top edges.
Alright, this is where we left 3 weeks ago until yesterday.
I was planning to change the screen and power button in one go when it would go on my nerves just too much. over time in the last 2 weeks though, the screen started to have some kind of burn-in effect where if you had an app open for some time it wouldn't wholly disappear after closing.
similar to this but more at the corners and not in the middle, like a vigniette
So I planned on changing the display as soon as i'd find time.
Ordered a new screen 2 days ago and yesterday it happened.
I plugged my phone into my computer to charge and after maybe 3-4 minutes (the screen was turned on from use) the screen suddenly turned bright red and after 3-4 seconds it shut off.
then it just entered a boot loop with the apple logo showing for a couple of seconds then a 'blue screen' (mostly white or some off white color) showing for a couple off seconds, it shutting back off and repeating the whole shabang.
it did it the whole night now so that the battery was fully drained this morning.
Now what my main questions are and where I hope to maybe get some help or input from you guys: I read an article stating that an issue with the proximity sensor flex cable could be responsible for this aswell as maybe a wrong (too long) screw for the cover of the lcd cable. I tried ruling out the prox cable one by trying to boot it up without the cable attached but nothing happened so I'm not sure I did it right.
What would you do to rule out one of these 2 possible mistakes?
Also, could it even be the screws now that it had been working just fine for over 2 weeks after me opening it....
Would you try to replace the screen (it's a full front panel so it would also have camera plus prox sensor) if it arrives (propably) tomorrow?
I'd be really happy for any input or advice from you and thanks a lot in advance already for ANY answer since I don't want to give up the phone just yet!
And have a nice day :)
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Here's the issue...with water damage, all bets are off. You did a good DIY cleanup but you still let it simmer in rice for several days, which is probably why you are having issues today. The water is inside the phone, on the logic board and under the shields, even under the IC's. The rice is nowhere near where the water is. So while it “may’’ soak up some water vapour, the real problem is the mineral deposits that can cause short circuits or the corrosion that is taking place as the water evaporates. Leaving the power on the device accelerates the process. The longer you let a phone sit in rice, the more time you are giving corrosion to damage your logic board. The saltier or harder the water is, the more damage will occur. The water needs to be displaced, not evaporated.
If you disconnect the FCAM/Prox Flex and the phone doesn't boot, then that is not the solution. You will have to have the board looked at by an experienced micro-solderer.
Was dit antwoord nuttig?
Score 2
3 opmerkingen:
ok, but wouldn't submerging the motherboard in isopropyl do that?
the water is from a river so no salt though i don't have a lot of information about how rich the water is with minerals.
door
No submerging the logic board does not do this because the alcohol does not penetrate below the shields and even if it does, it has no erosive action to clean up the corrosion. An ultrasonic cleaner is used to achieve deeper cleaning. I would side with Minho here.
door
disconnecting the front camera proximity sensor was the first thing I thought of for this..
door
Voeg je antwoord toe
Domi Hesse zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 3
Altijd: 807
