Why is my fire stick audio not working correctly
Why does the audio on my fire stick keep going in and out like it’s stutterinG
Is dit een goede vraag?
There are 2 main possible causes.
1) The speed of your Internet is too slow. Most content requires about 3mbps to function normally.
2) There isn't enough power going to your Fire stick. When it is low in power it will be slower than normal with possible reboots when it tries to do intensive processing.
Was dit antwoord nuttig?
All problems are not created equally. But this worked for me. I simply put it on pause for a couple minutes. Then started it, problem solved. Clearly a buffering problem.
This is not the solution.. This
Happens with alot of peoples. I've borrowed firesticks that work fine on one tv; but another tv the audio is either non existent or stuttering; video playback works completely fine. Still have not found a fix myself besides use my other tv. Hope a real article comes out with true fixes.
Thank you. This fixed mine.
I tried turning off the Dolby, didnt work. So then I tried changing the resolution of the video from 1080 to 720 and presto! No more stuttering audio. My TV is about a 42 in so it doesnt seem to make the picture any different for me , but maybe a larger TV would not show the crisper video. Idk, but it worked for me
This worked for my old westinghouse 32 inch tv
Been trying to fix this for weeks. Changed wifi access point. Then tried 5G wifi. Changed back to back hdmi connector feeding not so new LG TV. At last a cure! Pictures good enough for me and probably the TV. (Resolution was set to Auto - now 720P)
I have same problem, audio coming and going. Was OK for months, now all of a sudden it starts cutting out. I read and tried all the solutions, no luck, until I read the Display solution posted above by equus3n. i changed the Display from Automatic to 720. BINGO, problem gone !!!!!!
My fire stick has background noise like I’m watching two shows at once I’m so frustrated what can I do
I can’t FF thru commercials AFTER DVRd something. I CAN FF thru commercials during the recording process
My fire stick audio started skipping g a few weeks ago and I had no idea why. I tried a few things but nothing worked until one day I realized that my echo dot had connected to my fire stick/tv. Once I disconnected the Dot from the fire stick (simply by saying “Alexa disconnect from FireTv”), it started working perfectly again.
Found it! The cache fills up and it can't buffer. Home/settings/apps/amazon music Force Stop, clear cache
I disconnected my fire Stick 4K from TV HDMI then disconnected power from The fire stick. Works normal. I find once a month recycle keeps it fresh and working great.
My firestick auto work then doesn't on the sports Events and pay preview. Can anyone help.
My audio is robotic, stuttering, etc., at first it only occurred while watching Disney+. Now it is happening on the other apps as well. If I stop/go back out then continue watching the movie or change the channel then go back to the original channel the issue stops…for a lil while. My LG is approximately 3 years old. I’ve cleared the cache on all the apps. My internet speed is the fastest available and generally speaking, there maybe 3 devices tops using the internet at any one time(one of which is connected via ethernet) SOOOOOOOOOOOOOO Now I’m going to try 1st reseating the hdmi etc and see what happens…..wish me luck
I replaced the HDMI with a new one and it fixed it.
I was having dual audio playing and the starting and stopping i changed from auto to the 720 so far so good ty
Delete an app to get more memory
Clear cache in settings
Reboot device.
I changed my audio from auto to PCM and I changed the video resolution to 720 and this fixed the problem
Isn't changing your video resolution to 720 a real crap answer?
Afgelopen 24 uren: 8
Afgelopen 7 dagen: 47
Afgelopen 30 dagen: 214
Altijd: 78,306
7 opmerkingen
What is the speed of your Internet connection?
door S W
This happens from time to time. I simply reseat the fire stick in it's HDMI port and it typically fixes the sound stutter. If doing that a few times does work try a different port on your TV.
door Mike Carbary
door Terry Kloss
Reset your bluetooth headset Uninstall reinstall
door Cecil Ray Burnett III
Ok, I think I found a solution to this problem. So far, it has worked for me. I unplugged my internet modem and my WiFi router for 10 seconds. First, I plugged my modem back in and let it start completely back up. Once it started, I plugged my WiFi router back in and let it start back up. Internet speeds and WiFi speeds much faster now. No more sound cutting in and out.
door Jack Wiggins
2 commentaren meer tonen
