Ga door naar hoofdinhoud
Model A1312 / Mid 2010 / 3.2 GHz Core i3 or 2.8 & 3.6 GHz Core i5 or 2.93 GHz Core i7, ID iMac11,3
382 Vragen Bekijk alle
eBay used power supply damage?
Hey community,
I recently bought a new power supply from eBay. I'm not sure to try it out inside my iMac because the board looks kinda water-damaged (see attached photos).
What do you think about it?
Thanks for answering,
Leon
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
What you are seeing is a coating thats applied to the board at the end of the manufacturing process. It protects the board from moisture & corrosion.
Was dit antwoord nuttig?
Score 2
3 opmerkingen:
Okay, thank you!
door
But why is the coating white just on some areas?
door
Thats a fair question! I can't tell you why it so splotchy a job.
I suspect it's sprayed on and the coating then pools a bit in the hollows.
door
Voeg je antwoord toe
Leon zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 62
