Ga door naar hoofdinhoud
The Xbox One S, designed by Microsoft Corporation, was released on August 2016. The Xbox One S is a redesign of the Xbox One.
428 Vragen Bekijk alle
Will not load OS
My Xbox One S has been having issues. It powers on but does not display any on screen. The controller is blinking looking for the Xbox. The Xbox makes all the power noises to let u know it is on. When I do the hard reset and hold down the power button and reset for 10 sec it loads in low res mode. It will work until the Xbox is restarted where I will need to do it again. It has become daily. My warranty should be up as I bought it in 2016. What has gone wrong? Please not that I change the screen res each time to back to 1080p.
Changed TV, Hdmi cable, power source, so I think its the Xbox
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
You've got a bad hard drive at the least, bad motherboard at the worst. Before you open it up and remove the sticker, try Xbox Support. They might get a replacement for you, they've been very good in the past for me. Good luck!
Was dit antwoord nuttig?
Voeg je antwoord toe
tommy lee zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 2
Altijd: 81
