Ga door naar hoofdinhoud
Second generation of Wi-Fi iPad, released on March 11, 2011. Model number A1395. Repair is difficult and will require heat.
250 Vragen Bekijk alle
Power button working when turning on but not working when booted
Hey Guys, So two things happened so i cracked the screen last week and ordered a new digitizer on amazon and the other day my ipad got submerged in water and wasn't working and yesterday a bag of rice fixed my IPad and my new digitizer came but my power button seems not to be working i thought replacing the digitizer would fix it but it didn't power buttton only works when powering the device on from shutdown state but when my IPad is booted to IOS the power button is not working and also touchscreen and the touchscreen weren't also working before i replaced the digitizer and reflashing the firmware and restoring didn't fix it the only way i can turn on my device is pressing the home button in The OS but it works pretty fine i can go to recovery mode but it's not working in The OS Itself sorry for my poor english
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Can you try holding the power button while it's on and see if that works?
Was dit antwoord nuttig?
Score 1
2 opmerkingen:
Yes it does restart my IPad and screenshot also works
door
Okay so the issue is that the smart cover sensor which I think is located right next to the volume button area is liquid damaged.
So for the mean time to avoid this power button issue you need to disable Smart Cover unlock in settings.
door
Voeg je antwoord toe
Shuncey Balba zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 3
Altijd: 75
