Can't receive incoming landline calls. It gives caller a busy signal
My phone is hung up properly. I can make outgoing calls but cannot receive incoming. The caller receives a busy signal when calling.
Is dit een goede vraag?
Hi @jillharrington1 ,
What signal do you get if you disconnect your landline phone from the phone socket and then call your number from another phone? (assuming that you have nothing else connected to the phone line - if so disconnect it as well e.g. another phone, adsl modem etc)
Can you hear any noise on the line when you pick up your phone and just dial a digit to break the dialing tone? A good line should be quiet, no static or noise.
If you still get a busy signal with everything disconnected from the phone line and your line is noisy (or even if it is not) contact your phone service provider and report the problem.
Tell them what you have tried.
Was dit antwoord nuttig?
4 years later...
So I was having intermittent internet issues (which happens every 5-6 months or so) the techs say this is common (?!) but everyone else says "copper is dead". I would agree but I can't spend $200 on internet + landline and this is the least expensive way to go.
I get a dial tone when I pick up the landline (but it's oddly distant-sounding) and when I call another phone I get a fast-paced busy signal (very strange) since I'm calling mobile phones that all have call waiting and I know the phones that I'm calling are not in use.
I ordered a new landline so hopefully, that will address the phone issues but the intermittent internet is another story.
Tech is scheduled for this coming Tuesday but they were just out 2 weeks ago! And about 3 weeks before that, and 2 months before that, and 4 months before that (and so on). 😒
PS
I don't hear static or anything other than the dial tone when picking up the landline. When I call another phone I get busy signals. I had tech support call the landline in question and he said it "timed out" but eventually turned into the fast-paced busy signal.
I'm assuming that the phone is connected to your internet modem and is not connected to a separate telephone line socket i.e. voice over internet connection (VOIP), is this correct?
If so, try resetting the modem by switching it off, waiting 5 minutes and then turning it back on again.
Allow it to initialise and then check if you can make/receive calls OK.
If still no good check the phone settings in the modem's setup page.
If you don't know what they should be or if they're OK or not contact your service provider and ask them
If they're OK, still contact your service provider to find out why outgoing/incoming calls aren't getting through, especially if your internet is working at the time
This worked like a charm! Thanks for sharing :)
Hi @ndduncan
If you disconnect everything from your telephone line, what signal do you hear in another phone e.g. a mobile phone, that you are using to call your landline number, ringtone, engaged tone, voice announcement or nothing at all?
If you get the engaged signal, voice announcement or nothing at all contact your landline service provider about the problem
If you hear a ringtone signal, use a pair of scissors or a screwdriver to short out the two telephone wires in the phone socket in your premises when you hear the ringtone in the calling phone.
If the ringtone stops in the calling phone when you do this, this proves that the line is good to the premises and that there may be a problem with the base station or the cord to the base station, if it is a portable phone or the phone itself if it is a corded phone.
If the ringtone continues in the calling phone when you do this then there is a problem with the line or you're not doing it correctly. If you're sure that you're doing it right then call your landline service provider about the problem.
What is the make and model number of the phone?
Afgelopen 24 uren: 18
Afgelopen 7 dagen: 161
Afgelopen 30 dagen: 535
Altijd: 42,235
2 opmerkingen
I simply get nothing when I disconnect the line.
door David Duncan
Have tried disconnecting line and power in order for phone to reset. No luck.
door David Duncan
