Ga door naar hoofdinhoud
The Expression Photo XP-960 wireless, wide-format Small-in-One printer puts professional-quality photo printing at your fingertips.
15 Vragen Bekijk alle
Why is my printer only printing from the rear print tray
why is my printer only printing from the rear print tray
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
REF: https://files.support.epson.com/docid/cp...
The link above is to your user manual. First, I would check the basic print settings. Go to page 86 if you are using Windows or page 109 for OS X, and see what the paper source is set to (Page 89 gives the options and their meanings).
Also, go to page 66, and run through the "Selecting the Paper Settings for Each Source - Control Panel". Here you can change the default paper size for each tray, so when you set the paper source in Windows/OS X to auto, it will know which tray to pull from based on the paper size configured for each tray.
Was dit antwoord nuttig?
Voeg je antwoord toe
Tony Fishwick zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 7
Altijd: 1,904
