Ga door naar hoofdinhoud
Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Vragen Bekijk alle
iPhone 6 Touch screen not working after water damage.
Long story short, my phone got water damage and wouldn't turn on, I bathed the Logic Board in alcohol and put it back together and now it works, with a catch.
My LCD screen is working, some diagonal lines and the brightness might be a bit lower (I cant remember if I set it low.) And a brighter section in the top right of the screen.
However the biggest issue is the touch screen isn't working should I buy a new screen or is there some other fix I should try before this.
Thanks!
EDIT: Looks like I fixed the touchscreen myself, only thing is the right side of the screen doesn't work so it looks like I will be buying a new screen after all.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Just to follow-up on your previous question and now this one, yes, I would try a new screen. If the problem doesn't go away, they you may have a problem with the Touch circuit on the logic board, which would require a micro-soldering repair.
Was dit antwoord nuttig?
Score 2
Voeg je antwoord toe
Matt zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 2
Altijd: 1,458
