Ga door naar hoofdinhoud
1.4GHz or 1.6GHz Processor / 64GB or 128GB SSD
162 Vragen Bekijk alle
Battery has swolllen, can see the damage on the device
Good day,
The battery has swollen in the MacBook Air 11" the damage can be seen on the device. my question is if I order the replacement battery fix kit, do I receive all the necessary equipment to open the device e.g T5 screw bit?
Will there be other damages?
Thank you
Kind regards.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
You should receive everything you need to perform the repair in the kit. Other damages to the device could potentially be to the trackpad, case, and -if it's bad enough- the keyboard. I'd really recommend replacing the battery first before you try looking into other damages as just replacing it may be enough. I've seen MacBook batteries so swollen they are literally crackling and moving after being taken out and the device was fine after the replacement. Just be careful!! :)
Was dit antwoord nuttig?
Score 1
1 Opmerking:
Thank you.
Kind regards.
door
Voeg je antwoord toe
Stefan Coertzen zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 2
Altijd: 58
